Speedo Drive Wheel Fitting
Blenks
Main scooter: Lambretta S3 Li150
Just about ready to begin the assembly of the front hub. Managed to get the old speedo drive off as suggested in Stick's. Is there a tried and tested method of fitting the speedo drive wheel? Is it best pressed on with a vice or tapped on with mallet and block of wood?. Should I grease it prior to fitting? Just for info it is the metal type from MB
Paul
db67
Putting it in hot water prior to fitting seems to be one of the methods suggested, I think it states this in Stickys manual ;)
Muppet
I used a flat block of wood and a neoprene mallet after heating in hot water
C’est la vie
