Px Upgrade
ducksta
Hi Guys got a standard px electric start engine and a shed full of bits so I am thinking of fitting a dr177 kit taking the ring off the flywheel and fitting a 24mm carb with the polini Venturi 22 tooth clutch gear and a sip road 2 exhaust, what would I expect performance wise.
RGC GEOFF
Main scooter: Vespa GTr BGM 190
DR 177 is a very good kit.
If you have a P200 crank you add a 5mm base plate to the cylinder.
Cut a bit the crank and open the inlet, work on the piston.
The DR cylinder can be really optimised.
Polini 177 Cylinder head is more adapted than the crap DR's one.
Clutch with xl springs
I wouldn't use a 22 tooth clutch withe 68 standard crown but more a complete 65/22 or 23 transmission.
https://www.facebook.com/GF.Evrard/vide ... 779521799/
Built not bought...
ducksta
Cheers just wanting to use my spare bits up need someone to do the porting on the barrall
Norrie Bodge
@ducksta
By the loooks of those piccys m8
I’d Pm RGC GEOFF & ask him if he’d tune it 4u
