Tank venting
Posted: Fri Dec 29, 2017 1:37 pm
by chippy
Thinking of fitting an aero cap and using long range tank with direct access for fueling so no filler cap on tank. So would a vented aero cap suffice or would a breather need to be put into fuel tank. Thanks
Re: Tank venting
Posted: Fri Dec 29, 2017 6:38 pm
by holty
if the cap is vented, then cant see why you would need another vent as well, should be fine.
Re: Tank venting
Posted: Fri Dec 29, 2017 7:59 pm
by chippy
holty wrote: ↑Fri Dec 29, 2017 6:38 pm if the cap is vented, then cant see why you would need another vent as well, should be fine.
Thanks for that holty
