Tank venting
chippy
Thinking of fitting an aero cap and using long range tank with direct access for fueling so no filler cap on tank. So would a vented aero cap suffice or would a breather need to be put into fuel tank. Thanks
holty
Main scooter: lambretta gp
if the cap is vented, then cant see why you would need another vent as well, should be fine.
chippy
holty wrote: ↑Fri Dec 29, 2017 6:38 pm if the cap is vented, then cant see why you would need another vent as well, should be fine.
Thanks for that holty
    Users browsing this forum: Amazon [Bot], Google [Bot] and 6 guests
