Rear shocker
Posted: Sun Dec 03, 2017 4:29 pm
by Tractorman
If a series 2 body has a series 3 engine in what rear shock should it have, please?
Re: Rear shocker
Posted: Sun Dec 03, 2017 4:46 pm
by Muppet
Series 2 shock
oops
Re: Rear shocker
Posted: Sun Dec 03, 2017 4:47 pm
by HxPaul
Tractorman wrote: ↑Sun Dec 03, 2017 4:29 pm If a series 2 body has a series 3 engine in what rear shock should it have, please?
Their is no difference between series 2 and series 3 engines,the difference is between engine covers.I have a series 2 engine with a series 3 engine cover in a series 2 frame,I use a series 3 (305mm) rear shocker because the series 2 shocker makes the carb manifold sit to high and hits the frame,it seems to ride ok and I've done hundreds of miles with it like that.300mm is also the length of a series 3 shock,it just happens that I had a 305mm shock on the shelf so i used that.By the way,if you use a series 3 engine cover in a series 2 frame make sure you use a kickstart to fit.
Re: Rear shocker
Posted: Sun Dec 03, 2017 5:35 pm
by GTFOMWSC
some series 3 spanish engine cases are different and you'll need a 310mm shock with it and if your frame is not spanish you'll need a spacer as the frame/engine mounts are different roughly 10mm difference
Re: Rear shocker
Posted: Sun Dec 03, 2017 7:42 pm
by garry inglis
Well I always thought it was the front fork links on a seires 2 have a different curve to a seires 3 fork links equating to the 10mm difference in shock length
Re: Rear shocker
Posted: Tue Dec 12, 2017 9:59 pm
by shocky
garry inglis wrote:Well I always thought it was the front fork links on a seires 2 have a different curve to a seires 3 fork links equating to the 10mm difference in shock length
Correct Image
Sent from my SM-G903F using Tapatalk
