Rear shocker
Tractorman
- registered user
- Main scooter: Lambretta li150 special
- Contact:
If a series 2 body has a series 3 engine in what rear shock should it have, please?
- HxPaul
- registered user
- Main scooter: lambretta Li 150
- Contact:
Their is no difference between series 2 and series 3 engines,the difference is between engine covers.I have a series 2 engine with a series 3 engine cover in a series 2 frame,I use a series 3 (305mm) rear shocker because the series 2 shocker makes the carb manifold sit to high and hits the frame,it seems to ride ok and I've done hundreds of miles with it like that.300mm is also the length of a series 3 shock,it just happens that I had a 305mm shock on the shelf so i used that.By the way,if you use a series 3 engine cover in a series 2 frame make sure you use a kickstart to fit.Tractorman wrote: ↑Sun Dec 03, 2017 4:29 pm If a series 2 body has a series 3 engine in what rear shock should it have, please?
- GTFOMWSC
- registered user
- Main scooter: GP230 Super Monza CS Tuned
- Contact:
some series 3 spanish engine cases are different and you'll need a 310mm shock with it and if your frame is not spanish you'll need a spacer as the frame/engine mounts are different roughly 10mm difference
the man don't give a f@@k
- garry inglis
- registered user
- Main scooter: ts1 230 and rb200
- Contact:
Well I always thought it was the front fork links on a seires 2 have a different curve to a seires 3 fork links equating to the 10mm difference in shock length
Correctgarry inglis wrote:Well I always thought it was the front fork links on a seires 2 have a different curve to a seires 3 fork links equating to the 10mm difference in shock length
Sent from my SM-G903F using Tapatalk
