Rb250 oil mixture percentage
Simonwwfc26
3% or 4%
Brand new build
High spec engine
No mileage
What would you guys recommend
Simonwwfc26 wrote: ↑Sat Nov 04, 2017 8:07 am 3% or 4%
Brand new build
High spec engine
No mileage
I believe AF recommend 4%
leigh
I’ve been running an RB 22 for years on 3%. Not had any issues
Leigh
Scooterdude
If you read the set up page on the af site it states 4%.
The AF theory is that feeder ports from intake straight to transfers, then directly into bore, means that less mix (also less oil) goes into the crankcase mouth to lubricate the big end bearing. As such, sticking to 4% may still only result in the same quantity of oil making it to the crank as 3% might on a TS1.
Scooterdude
I'll stick with 4% as instructed by Harry Barlow and also Rayspeed.
Simonwwfc26
Dan may confirm what % if possible as he built the scooter I own now
Simonwwfc26
Many thanks for advice guys appreciated
