Sip speedometer rpm
Leviblue
Main scooter: Lambretta li 125 special
Hello wandering if anyone could help connected brown wire from speedo to brown lighting wire in headset I'm using an r rated spark plug and resisted plug cap problem is rpm is reading about 4000 too high so when scooter is running about 6000 rpm it is reading 10,000.cheers
GeorgeS
That may be the 'sparks per rev' setting. What stator do you have?
Sent from my SM-G920F using Tapatalk
garry inglis
have you set the speedo to one spark per revolution and not two
Leviblue
I am using a good quality Indian stator from antony tambs. ..
