Stripped thread- what are my options?
db67
Hi, just after a bit of advice, had the mag flange off my engine this afternoon to fit a new mag gasket & repack the bearing with grease & when it came to tighten everything down one of the mag/crankcase nuts wouldn't tighten & just kept spinning, tried a new nut but still no joy, fitted a slightly longer stud which bit slightly but still not enough to hold it tight:roll: just wondered what my options are? can it be taken out to m7 ? or does it need an insert? thanks for any info ;)
hendy
Just helicoil it. Easy, cheap, good.
db67
I did think about this option, just wasn't sure if there was enough "meat" in this area to do this. thanks ;)
