Saying Hi
NEW MEMBER? - You must now introduce yourself here first BEFORE you can post in any other section!
Say hello and let us know a bit about you and what scooter you own, etc...THEN you will be able to post elsewhere.
mattyboyc
Main scooter: Lambretta Li 150 series 3
Hi all,
My name is Matt and I’m from Aldershot Hampshire. I have been lurking around the forum for a little while now and have just ventured into the classic scootering scene with a 1963 Li 150 series 3. I hope to be a regular visitor and am looking forward to gaining a wealth of knowledge from the more experienced scooterist.
YAMLAM
welcome aboard
win or lose have a booze
10 inch Terror
Xbox live gamer tag: No.
Welcome Matt, I’m just down the road in Farnborough, if you ever need any advice or need to borrow tools give me a shout. Aldershot has quite a healthy scooter scene too, so plenty of like minded people about.
mattyboyc
Thank you for the welcome, as for tools I shall be raiding my step fathers old shed for all the older imperial spanner’s.
Martin20
Welcome to the forum Matt.
Welcome aboard
10 inch Terror
mattyboyc wrote: ↑Fri Oct 06, 2017 6:44 pm Thank you for the welcome, as for tools I shall be raiding my step fathers old shed for all the older imperial spanner’s.
You’ll be out of luck then Matt, every nut and bolt on a Lambretta is metric 😂
mattyboyc
:D The opposite to what I have, I was looking for a Allen key to adjust the clutch cable the other night and I found every size bar the 3.5mm I needed, so that was the first purchase.
10 inch Terror wrote: ↑Fri Oct 06, 2017 9:04 pm
10 inch Terror
I was referring to specialist tools like rear hub puller / holder , flywheel puller / holding tool, clutch compressor, clutch holding tool, crank puller / holder / removing tools, fork spring compressor, steering clamp spanners etc etc. If you don’t have access to any I’ll lend you mine mate.
mattyboyc
10 inch Terror wrote: ↑Sat Oct 07, 2017 7:41 am I was referring to specialist tools like rear hub puller / holder , flywheel puller / holding tool, clutch compressor, clutch holding tool, crank puller / holder / removing tools, fork spring compressor, steering clamp spanners etc etc. If you don’t have access to any I’ll lend you mine mate.
Thanks very much for the offer and I have no doubt at some point I will be calling on your expertise and extensive tool kit.
