Casatronic backfiring...
psychedelicropcircle
Fitted mid-season 2016 seems to be showing signs of a stator breaking down.
Surely not bearly done 3k. So far pulled the ignition & changed the plug no change! I appreciate there’s plenty checks to do. Would it backfire if it was a split reed?
Grumpy225
Is it back firing out of the carb or the exhaust?
Exhaust I think! I’d need to fire it up to be sure. Thing that made me think reed is it has a decent spark. I’ll know Saturday when I investigate further.
Reeds fine 😡 it’s electrical defo need to pull the other ignition apart and see wots wot! I’ll be complaining like f**k if it’s packed up so soon😡
On the up side I needed a victim to test out my leakdown kit, looks like it’s me😌
cev
Did you get to the bottom of this Scott?
cev wrote: ↑Fri Oct 27, 2017 5:36 am Did you get to the bottom of this Scott?
Apparently getting a replacement FOC👍
