TV headset ?
nellyboyo
I`m a TV novice and just been lucky enough to get one........Are all the headset part interchangeable with SX/ LI special ??
Need a headset top and rim ...cheers in advance
chippy
I believe the headset and internals are the same apart from the headset bottom of a chrome ring model. Even so, if it's anything like finding a top to match correctly on a GP headset bottom it makes you wonder. If you can I would take the bottom to parts fairs etc and try tops on it as it's amazing how different the fitment can be even with the same part number. Good luck
nellyboyo
OK tidy , thanks for that , I`ll see if I can get the original repaired first ....the lip that the headlight rim bezel fits over it snapped off in a few places
chippy
Sure a good ally welder will be able to sort it for you
