scooter lab air fuel ratio article
tavspeed
was looking at a article on scooter lab,about setting your scoot up with a aem x series afr kit,anyone used similar,they are about £175 on ebay,wouldnt be bad value if a few clubbed together for one,and you would be setting your jetting in true road conditions,oh and do they work with 2 strokes,cheers
RManson
I'm using a FAST A/F meter on my Rotax bike...
http://www.fuelairspark.com/fas/motorcy ... ensorhtml/
ImageRotax Lamby build-208 by PotvinV8, on Flickr
ImageRotax Lamby build-207 by PotvinV8, on Flickr
Works great and has allowed me to fine tune the jetting without a dyno. When not in use, I simply plug the bung in the exhaust in order to preserve the O2 sensor. The unit has a playback feature which is useful so that you're not trying to read the thing at WOT in third gear! They are a bit pricey though, but I have a few projects in which to use it on, so the cost was justified. I think sharing it amongst a couple guys to offset the cost would be a good idea.
