Engine parts rebuild list ?
johnny650
has anyone ever compiled a complete check list of the basic parts needed for ...say a standard series 3 Li150 engine rebuild ? could be handy for anyone like me who is in the process of collecting bits for a spare crankcase build
Here's a start ..... Not my work, forget where i copied it from.
casing
brake arm
brake arm circlip
brake cam & shim
brake cam grease nipple
brake shoe circlips & plates
brake shoe pivot pins & washers
brake shoe spring
brake shoes
bumpstop
bumpstop washer
chain
chain guide nuts & washers
chain guide studs
chain guide, bottom
chain guide, top
clutch arm
clutch arm spring
clutch bellhousing
clutch circlip
clutch corks
clutch lever
clutch nut
clutch shaft
clutch shaft circlips x4
clutch shaft o ring
clutch shim
clutch spider
clutch springs
clutch steels
clutch tab washer
clutch thrust thimble / brass bush
clutch top plate
crankshaft
crownwheel
crownwheel bearings / bush
cylinder
cylinder cowling
cylinder head
cylinder head nut kit
cylinder studs
drive side bearing
drive side bearing plate screws
drive side seal
drive side seal plate
drive side washer
endplate
endplate bearing
endplate bearing circlip
endplate dowels
endplate nuts
endplate shim
endplate studs
endplate washers
engine bolt
engine mounts
engine studs 14 x M6x33
exhaust casing studs 2 x M8
exhaust cylinder studs M7
exhaust gasket
exhaust header pipe
exhaust nuts & washers
flywheel
flywheel cowling
flywheel dustcover
flywheel dustcover circlip
flywheel nut & washer
front sprocket
front sprocket bolt
front sprocket collar
front sprocket oil thrower washer
front sprocket sliding dog
front sprocket spring
gear cog loose 1st
gear cog loose 2nd
gear cog loose 3rd
gear cog loose 4th
gear selector balls
gear selector pin clips x2
gear selector pins x2
gear selector shaft
gear selector shaft bolt & washer
gear selector shaft bush
gear selector shaft o ring
gear selector spring
gear selector wishbone
group cluster
group cluster bearing outer track
group cluster needle bearing
group cluster shim
group cluster track shim
inlet gasket
inlet manifold
inlet nuts & washers
inlet studs
kickstart buffer
kickstart circlip & washer
kickstart inner bush
kickstart lever
kickstart outer bush
kickstart piston
kickstart piston pin
kickstart piston plate
kickstart piston spring
kickstart ramp
kickstart ramp bolts & washers
kickstart seal
kickstart shaft
kickstart spring
kickstart stop
Kickstart piston circlip
Kickstart stop washer
layshaft
layshaft bearing bush
layshaft needle bearing
layshaft o ring
layshaft shim
mag housing
mag housing bearing spacer
mag housing circlip
mag housing gasket
mag housing grommet
mag housing inner seal
mag housing outer seal
mag housing stator wiring plates
mag housing stator wiring plates gasket
mag housing studs 3 x M6x25
mag side bearing
oil drain plug & fibre washer
oil filler cap & fibre washer
oil level plug & fibre washer
piston
piston pin
piston pin circlips
piston rings
rear bearing
rear bearing flange studs 4 x M6x21
rear bearing flange thick
rear bearing flange thin
rear bearing housing nuts & washers
rear bearing seal
rear hub & cone
rear hub nut & washer
rear hub nut lockwasher set
rear hub spacing washer
side casing
side casing dowels
side casing gasket
side casing nuts & washers
small end bearing
stator
stator bolts & washers x3
stator wiring clip
woodruff key
johnny650
Wow thats brilliant ! thanks sorry for the delayed response (note to self ...must remember to set posts to instant notification doh......)
I started making a list myself yesterday so I'll check my list with this one and post when finished.
Cheers Corrado ;)
corrado wrote: ↑Wed Aug 30, 2017 6:07 pm Here's a start ..... Not my work, forget where i copied it from.
casing
brake arm
brake arm circlip
brake cam & shim
brake shoe spring
brake shoes
bumpstop
bumpstop washer
chain
chain guide studs
chain guide, bottom
chain guide, top
clutch arm
clutch arm spring
clutch bellhousing
clutch circlip
clutch corks
clutch lever
clutch nut
clutch shaft
clutch shaft o ring
clutch shim
clutch spider
clutch springs
clutch steels
clutch tab washer
clutch top plate
crankshaft
crownwheel
cylinder
cylinder cowling
cylinder head
cylinder studs
drive side bearing
drive side seal
drive side washer
endplate
endplate bearing
endplate dowels
endplate nuts
endplate shim
endplate studs
endplate washers
engine bolt
engine mounts
exhaust gasket
exhaust header pipe
flywheel
flywheel cowling
flywheel dustcover
front sprocket
front sprocket bolt
gear cog loose 1st
gear cog loose 2nd
gear cog loose 3rd
gear cog loose 4th
gear selector balls
gear selector shaft
group cluster
group cluster shim
inlet gasket
inlet manifold
inlet studs
kickstart buffer
kickstart lever
kickstart piston
kickstart ramp
kickstart seal
kickstart shaft
kickstart spring
kickstart stop
layshaft
layshaft o ring
layshaft shim
mag housing
mag housing circlip
mag housing gasket
mag housing grommet
mag side bearing
piston
piston pin
piston pin circlips
piston rings
rear bearing
rear bearing seal
rear hub & cone
side casing
side casing dowels
side casing gasket
small end bearing
stator
stator wiring clip
woodruff key
garry inglis
nice one corrado you should of added about £2 to£2500
Monty
something to remember when you see that cheap (200 quid) BARE casing on ebay. every nut washer and stud will need to be bought, why do people strip them down to that level most bits will be left on the shed floor when you have finished as no one wants a 2nd hand engine stud, but it all costs to replace
