Page 1 of 2
Inlet Manifold Gasket?
Posted: Mon Aug 28, 2017 5:05 pm
by Martin20
Evening All,
Planning to try a 22mm carb on my LIS150 in the not too distant future. Question is, do I need to fit an inlet manifold gasket, or can I get away with using gasket sealant? Also, if a gasket is recommended, is it OK to buy gasket paper and make my own? Sorry if it sounds a dumb question, but I have done loads of reading, and nowhere have I seen it give a definite yes or no!
Cheers
Martin
Re: Inlet Manifold Gasket?
Posted: Mon Aug 28, 2017 5:20 pm
by Scoot
Gasket sealant is fine
Sent from my iPhone using Tapatalk Pro
Posted: Mon Aug 28, 2017 5:51 pm
by bristolmod
use a cereal box- grease up the end of the inlet manifold and press down. Cut round the ungreased areas.
Chris
Posted: Mon Aug 28, 2017 6:38 pm
by hendy
bristolmod wrote: ↑Mon Aug 28, 2017 5:51 pm use a cereal box- grease up the end of the inlet manifold and press down. Cut round the ungreased areas.
Chris
Bad advice.
Use an "old el paso" nachos kit box; cereal boxes aren't Tuv approved.
Posted: Mon Aug 28, 2017 6:47 pm
by mick1
Is there a reason for not wanting to buy a ready made gasket ?
Sealants fine but I use sealant and a gasket.......belt and braces and all that.....
Posted: Mon Aug 28, 2017 7:02 pm
by hendy
mick1 wrote: ↑Mon Aug 28, 2017 6:47 pm Is there a reason for not wanting to buy a ready made gasket ?
I found that gaskets didn't cover the gasket face properly so made my own.
Posted: Mon Aug 28, 2017 7:17 pm
by Martin20
No, no reason. Just doesn't seem to be that many for sale, so wondered if they were really necessary!
Thanks for all replies guys. Think I will try a cereal packet gasket (cornflakes or weetabix, hmmm) with sealant.
Posted: Mon Aug 28, 2017 7:22 pm
by Adam_Winstone
I seem to remember that my genuine LI150S barrel has the same shape (round) and size inlet gasket as a TV175, which is different to the other L150s, so you might want to make your own anyway. I too would rather use a gasket than just sealant but a bit 'horse for courses'.
Posted: Mon Aug 28, 2017 8:38 pm
by Grumpy225
Martin20 wrote: ↑Mon Aug 28, 2017 5:05 pm Evening All,
Cheers
Martin
Gaskets are cheap and easy to come by. I literally have 100's of extras from various builds. Every gasket set comes with at least 1 intake and they are only used about 1/4 of the time in rebuilds (seal/bearing jobs).
If you are changing your manifold then replace the gasket (use gasket sealer). If you are using a cereal box then I look forward to reading how you motor has developed a mysterious air leak and you melted a hole in your piston. Good luck.
Posted: Mon Aug 28, 2017 10:00 pm
by hendy
Grumpy225 wrote: ↑Mon Aug 28, 2017 8:38 pm
I completely agree, and that is why I said to use a nachos box.
