Gearing set up.
idc23
Main scooter: lambrettatv175 3
Just getting the t.v 175 3 ready it has a Mugello 186,Scootopia 42mm ancillotti,Dellorto 26 phbh carb,i want the gearing so it pulls up hills,would a 16x46 be better than 14x47,it has the original tv box, not so bothered about top end speed,any thoughts appreciated.
Ian :D
garry inglis
Tv175 standard 46x15 is 4-82 and was always good with the 175 but 46-16 is 4-52 getting quite tall 47×15 is 4-92 witch might be better
garry inglis
Have a look at these set upsImage
Chris in Margate
Why not leave it standard ? About the best gearing set up you can have for your needs.
idc23
I have a 15x47 ,or a 15x46 4.9 or 4.8 a 14x47 came out ,remember i want it to pull up hills ,what shall i use.
Thanks Ian
garry inglis
Got this off Cambridge lambretta siteImage
garry inglis
Go on there site scroll down on home page and on the right it has the Facebook forum for mugello click on that and read
idc23
Thanks for reply's difficult to make the correct choice, will have a look.
Cheers Ian
14 x 47 = 5.28 final drive.
15 x 47 = 4.92 final drive.
15 x 46 = 4.80 final drive.
I'd opt for keeping the 14 x 47, it should go up anything in top gear with that ratio.
You [everybody] should download and learn to use the Lambretta gearbox visualiser by Tony Cassidy, it's a great bit of kit and tells you far more than just a series of numbers that may or may not mean much too you. You can see how the gears overlap according to the revs and you can compare 2 different gearbox set ups side by side.
Download it free from here .... https://avantone.wordpress.com/
    Users browsing this forum: Ahrefs [Bot] and 3 guests
