BGM non adjustable dampers
Posted: Tue Jul 25, 2017 2:10 pm
by john.t5
Bough a set of these for my GP and they seem to be about 10mm too short when fully extended and the front wheel is off the ground - To fit I need to get someone slightly heavier than me to sit on the scooter. They are indian forks with, I assume, factory fitted brackets. Any thoughts? Do I fit them like this or not???
Ta
John
Re: BGM non adjustable dampers
Posted: Tue Jul 25, 2017 2:59 pm
by shocky
What are your mounting point centers
Sent from my SM-G903F using Tapatalk
Posted: Tue Jul 25, 2017 3:01 pm
by john.t5
I'll check when I get home.
Posted: Tue Jul 25, 2017 4:00 pm
by Tractorman
john.t5 wrote: ↑Tue Jul 25, 2017 2:10 pm Bough a set of these for my GP and they seem to be about 10mm too short when fully extended and the front wheel is off the ground - To fit I need to get someone slightly heavier than me to sit on the scooter. They are indian forks with, I assume, factory fitted brackets. Any thoughts? Do I fit them like this or not???
Ta
John
So when you fit them and the scooters on it's stand the spring pressure will be on the dampers. I would check this out because something is not right.
Posted: Tue Jul 25, 2017 5:38 pm
by john.t5
Distance is 248mm
Yeah when on the stand they would be at full extension being forced apart by the springs.
Posted: Tue Jul 25, 2017 5:46 pm
by john.t5
Damper holes are 235mm centre to centre.
