BGM non adjustable dampers
john.t5
Bough a set of these for my GP and they seem to be about 10mm too short when fully extended and the front wheel is off the ground - To fit I need to get someone slightly heavier than me to sit on the scooter. They are indian forks with, I assume, factory fitted brackets. Any thoughts? Do I fit them like this or not???
Ta
John
What are your mounting point centers
Sent from my SM-G903F using Tapatalk
john.t5
I'll check when I get home.
Tractorman
john.t5 wrote: ↑Tue Jul 25, 2017 2:10 pm Bough a set of these for my GP and they seem to be about 10mm too short when fully extended and the front wheel is off the ground - To fit I need to get someone slightly heavier than me to sit on the scooter. They are indian forks with, I assume, factory fitted brackets. Any thoughts? Do I fit them like this or not???
Ta
John
So when you fit them and the scooters on it's stand the spring pressure will be on the dampers. I would check this out because something is not right.
john.t5
Distance is 248mm
Yeah when on the stand they would be at full extension being forced apart by the springs.
john.t5
Damper holes are 235mm centre to centre.
