Vespa P200e and related shifter gasket
Posted: Fri Jul 21, 2017 6:12 pm
I created a scan containing eight pictures of the gasket for the shifter mechanism. The original I used was from a P200e gasket set, but I thing the same gasket fits most if not all manual shift Vespas.
This may not print correctly for you. My file is a PDF which prints correctly on 8-1/2" x 11" paper and likely could be printed correctly on a larger sheet.
If you need a copy of the PDF, PM your email address to me.
