Vespa P200e and related shifter gasket
railfancwb
I created a scan containing eight pictures of the gasket for the shifter mechanism. The original I used was from a P200e gasket set, but I thing the same gasket fits most if not all manual shift Vespas.
This may not print correctly for you. My file is a PDF which prints correctly on 8-1/2" x 11" paper and likely could be printed correctly on a larger sheet.
If you need a copy of the PDF, PM your email address to me.
railfancwb
FWIW, the original gasket measured 0.024 inches thick while the copy I printed on kinda heavy paper measured 0.008
I presume the paper I printed on will serve adequately...
Edited attempting to correctly state the measured thicknesses. See next post.
railfancwb
What can I say? Math is hard - especially when it involves nasty old decimal points. Photos of the actual micrometer measurements - ten times what I erroneously stated above.
railfancwb
Gasket is 1-11/16 inch tall and 3-5/16 inch wide at its largest.
