Bgm damper fitting
Geocamper
Main scooter: Tv175 S2- Li 150 S2 Eibar
I'm fitting a new set of Bgm dampers with the Bgm brackets today.
My question is, Do I need to extend the shock a little when I'm fitting it? Or do fit it straight on without trying to extend it? I'm bit of a novice at this damper lark. I'm just thinking about the travel when braking. When heavy braking applied I'm thinking that the shock may bottom out due to the short rebound.
