26mm set up
servetaeire
Main scooter: 83 serveta exclusive 150 64 wi
stage 4 gp200 small block with Af big bore 42mm with breath sweet filter
had probs in italy with pwk 28mm and pm pipe would not work with breath sweet at all and guzzled juice spitting back juice everywere made it there and back over 4000km but ran s**t blew a piston and a fortune in 2t and juice hey but had a ball anyway :D
so going old school with 26mm on a stubby manifold Af 42mm and hoping to use the breathsweet aswell any tips on jetting needle etc :?:
gaz_powell
Same set up except scootopia clubman
300 float valve
X7 needle (middle clip)
AV266
118 MJ (may come down to 116)
Pilot 55
Air screw 2.5 to 3.5 out
Slide 40
Open mouth
Should get you somewhere near
servetaeire
open mouth? You reckon
servetaeire
Hsve a bn 266 any good
servetaeire
And aq266
