Any decent brake light switches for Vespa Sportique ?
Posted: Fri Jun 23, 2017 6:02 pm
Got 2 regular cheapo Swiss ones and both short out when they are screwed down to the frame
Switch is a normally closed type, press the button in to break the circuit.
Trouble is that when you push the button in, the contacts where the wires are soldered onto have so much play they can still touch the contacts on the shaft
Don't mind paying a bit extra for better quality
