Any decent brake light switches for Vespa Sportique ?
mushroom
Main scooter: Motovespa P200E
Got 2 regular cheapo Swiss ones and both short out when they are screwed down to the frame
Switch is a normally closed type, press the button in to break the circuit.
Trouble is that when you push the button in, the contacts where the wires are soldered onto have so much play they can still touch the contacts on the shaft
Don't mind paying a bit extra for better quality
