Vespa Cable Adjuster Threads
railfancwb
There is one other style in a set - a brass one. It appears to be M6 x ?.? as my thread gauge has only M6 x 1.0 and the brass one is finer pitch but tries to start in the M6 x 1.0
My best guess is these are the same for all manual transmission Vespa scooters.
wack 63
Main scooter: '71 GP TS1
If it has an 8 mm head then it may be for the throttle cable on the air box.
