But there are only 2 bolt holes on the back of the tank to attach where the seat bolts are. - no bolt holes at the front?mick1 wrote:+^ that's a bolt in tank, no straps required.
The tank doesn't have the grooves for tank straps either ? is there a bracket on the bottom to bolt to the frame ?alanscottj wrote:But there are only 2 bolt holes on the back of the tank to attach where the seat bolts are. - no bolt holes at the front?mick1 wrote:+^ that's a bolt in tank, no straps required.
I can see how the back bracket goes on using seat bolts - but I can't figure out how the other bracket attaches to the bottom front of the tank? There isn't anything on the tank underneath to attach?charlton_supporter wrote:Yes not the best idea in the world but once fitted seems to work well.
Sent from my SM-N910F using Tapatalk
