Long range tank straps
alanscottj
Anyone know where I can get straps for this tank? Many thanks Image
Jay71
Main scooter: SIL GP200
Do those tanks not bolt directly to frame? Not sure they use straps.
mick1
Main scooter: Li Avanti 225
+^ that's a bolt in tank, no straps required.
alanscottj
mick1 wrote:+^ that's a bolt in tank, no straps required.
But there are only 2 bolt holes on the back of the tank to attach where the seat bolts are. - no bolt holes at the front?
Sent from my iPad using Tapatalk
mick1
The tank doesn't have the grooves for tank straps either ? is there a bracket on the bottom to bolt to the frame ?
charlton_supporter
Main scooter: LI150 Special
TSR sell those tanks. I just fitted one to my Series 2. Not sure if they can supply just the strap.
Sent from my SM-N910F using Tapatalk
mick1
I stand corrected :oops: just checked the TSR site and it shows a strap and a second bracket.......bit of a hybrid fixing system (in my defence :) )
charlton_supporter
Yes not the best idea in the world but once fitted seems to work well.
alanscottj
charlton_supporter wrote:Yes not the best idea in the world but once fitted seems to work well.
I can see how the back bracket goes on using seat bolts - but I can't figure out how the other bracket attaches to the bottom front of the tank? There isn't anything on the tank underneath to attach?
charlton_supporter
The bracket fixes under the front seat mounting point and then the strap wraps round the tank. You access the bolt through the toolbox door.
