Page 1 of 2
Long range tank straps
Posted: Thu Jun 01, 2017 12:14 am
by alanscottj
Anyone know where I can get straps for this tank? Many thanks Image
Re: Long range tank straps
Posted: Thu Jun 01, 2017 10:39 pm
by Jay71
Do those tanks not bolt directly to frame? Not sure they use straps.
Posted: Fri Jun 02, 2017 7:21 am
by mick1
+^ that's a bolt in tank, no straps required.
Posted: Fri Jun 02, 2017 3:57 pm
by alanscottj
mick1 wrote:+^ that's a bolt in tank, no straps required.
But there are only 2 bolt holes on the back of the tank to attach where the seat bolts are. - no bolt holes at the front?
Sent from my iPad using Tapatalk
Posted: Fri Jun 02, 2017 5:05 pm
by mick1
The tank doesn't have the grooves for tank straps either ? is there a bracket on the bottom to bolt to the frame ?
Posted: Fri Jun 02, 2017 5:36 pm
by charlton_supporter
TSR sell those tanks. I just fitted one to my Series 2. Not sure if they can supply just the strap.
Sent from my SM-N910F using Tapatalk
Posted: Fri Jun 02, 2017 5:49 pm
by mick1
I stand corrected :oops: just checked the TSR site and it shows a strap and a second bracket.......bit of a hybrid fixing system (in my defence :) )
Posted: Fri Jun 02, 2017 6:56 pm
Yes not the best idea in the world but once fitted seems to work well.
Posted: Fri Jun 02, 2017 8:55 pm
by alanscottj
charlton_supporter wrote:Yes not the best idea in the world but once fitted seems to work well.
I can see how the back bracket goes on using seat bolts - but I can't figure out how the other bracket attaches to the bottom front of the tank? There isn't anything on the tank underneath to attach?
Posted: Fri Jun 02, 2017 9:10 pm
The bracket fixes under the front seat mounting point and then the strap wraps round the tank. You access the bolt through the toolbox door.
