Why did I have to retorque after an engine rebuild
Posted: Sun Apr 30, 2017 11:15 pm
by Davidsquaredson
Rebuilt my rally 200 engine. Case bolts torqued to 11 ft/lbs. 150 kms run in. Head still tight. But all but 1 of the case bolts needed to be tightened. Studs were not changed but I used new hardware. Why/how did they back off? Will I have check again at some point?
Sent from my SM-G928W8 using Tapatalk
Re: Why did I have to retorque after an engine rebuild
Posted: Mon May 01, 2017 12:12 am
by fluff34567
Non locking nuts will vibrate loose.. use a bit of thread lock liquid
Posted: Mon May 01, 2017 6:43 am
by garry inglis
It's with heat expansion when you first torque your head it was cold then after running those 150 kms it will have expanded and shrunk a few times through cooling and then getting hot again it's daft I No but that's why some engine builders run them for 1/2 hour let them cool then run them again for another 1/2 hour then 're torque this also lets every thing bed in after a build
Posted: Mon May 01, 2017 12:39 pm
by Davidsquaredson
Makes sense. Thanks for that. I was going to use titanium jet nuts (elliptical threads self lock) but replaced with what was there thinking it was fine for 10 years. I should be good now, will check in 50 kms.
