Why did I have to retorque after an engine rebuild
Davidsquaredson
Rebuilt my rally 200 engine. Case bolts torqued to 11 ft/lbs. 150 kms run in. Head still tight. But all but 1 of the case bolts needed to be tightened. Studs were not changed but I used new hardware. Why/how did they back off? Will I have check again at some point?
Sent from my SM-G928W8 using Tapatalk
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
fluff34567
Non locking nuts will vibrate loose.. use a bit of thread lock liquid
garry inglis
It's with heat expansion when you first torque your head it was cold then after running those 150 kms it will have expanded and shrunk a few times through cooling and then getting hot again it's daft I No but that's why some engine builders run them for 1/2 hour let them cool then run them again for another 1/2 hour then 're torque this also lets every thing bed in after a build
Davidsquaredson
Makes sense. Thanks for that. I was going to use titanium jet nuts (elliptical threads self lock) but replaced with what was there thinking it was fine for 10 years. I should be good now, will check in 50 kms.
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
