Fuel consumption 225
mr mugello
What mpg should I be getting with mugello 225 with 28 mill dellorto carb ? I,ve only done about 15 to 20 miles mainly town use and and had to turn on the reserve.
Scooterdude
Summat wrong there boss. Just as a comparison my Muggelo 199 with 28mm Delortto does around 80 miles to to 6.3/4 litres befor it goes on to reserve and that's spanking it as well.
mr mugello
Crikey. Bit of difference. No leaks, lol. Does goes through gears quick. Standard sx200 gearing. 4th gear does seem very low, high revs. Was filled with fuel can, 5 litres, only should have mentioned. How much does the reserve hold roughly, fast flow tap fitted ? Do I need to alter gearing, sprockets, with my top end kit.
mr mugello
Sorry. My carb is a 30mm phbh, not 28mm. Been a long day !
Scooterdude
Depends what tap your using. On a standard tank a Scootopia tap will give you 1/3 of a litre that's all. An omg tap will give you something like 3 litres but I've cut mine back so it gives 6.3/4 on on and 1.75 on reserve.
holty
Main scooter: lambretta gp
your final drive ratio will have an impact on mpg, if its revving high it will be using more fuel, maybe your jetting might be over-rich, those are the 2 main factors, have you done a plug chop ?
mr mugello
Will check on the tap fitted, but quick nosey in the tank, it looks low on petrol, when having to switch on reserve. Plug looks ok, colour.
purple_pill67
Main scooter: Jet200
Depends on the type of riding too.
My RT225 with bgm clubman and 28phbh does about 65 miles to 5litres if im commuting (town traffic and abit of dual carriageway and up and down the gears) but would do the same mileage on about 3.5litres if i went on one long run.
Thats standard jet/sx200 gearing.
Scooterdude
Just come back from a ride today on mine 107 miles and used exactly 7.5 litres that's including speeds of up to 73mph on the motorway (I know I couldn't believe it either!) but there you go 4.8-1 gearing on a late pacemaker gearbox.
Scooterdude
purple_pill67 wrote:Depends on the type of riding too.
That would put us in the same ballpark: 11-14 miles per litre.
