Brackets for front hydraulic cable
garry inglis
Thought you might like this I've used the rear break bracket that sits on top of the casing cut the top lug off and fit it to my top bolt feed a bit of rubber round the cable and pinch it up it works great better than a tywrapImageImage
Grumpy225
Clever. Make sure you get rid of any sharp angles on it or it will crack pretty quick,
