Decent modern carb set up for Indian stage 4 top end
eadmr04
I've got a GP200 with the standard Indian stage 4 top end and Indian Clubman exhaust. I want to try modern carb and wondered if anyone has any suggestions and set ups? Was possibly think of something like a Dellorto PHBH 26/28/30? Cheers.
bazza3004
Used dellys many times over the years and had good results but if your engines a standard 200 i would considder one smaller than 30 mil as you will prob get the same result but with better fuel economy.
eadmr04
bazza3004 wrote:Used dellys many times over the years and had good results but if your engines a standard 200 i would considder one smaller than 30 mil as you will prob get the same result but with better fuel economy.
Yes was thinking more like 26 or 28 but would consider 30 if opinion was that good results could be obtained.
gaz_powell
Iv put a 26 on a Stage 4 top end and a scootopia clubman - pulls well and still great on juice.
Minority
Main scooter: Li230 S3
Polini PWK 24mm
Suede Ed
Main scooter: SIL GP200
Dellorto phbl 25mm thru standard (drilled) airbox?
Mag
Main scooter: Carbon GP TS1
Suede Ed wrote:Dellorto phbl 25mm thru standard (drilled) airbox?
+1
HxPaul
I use one of these through a standard undrilled airbox http://www.scootopia.co.uk/product/7426 ... -22mm-carb
    Users browsing this forum: No registered users and 61 guests
