Hub stud thread
Posted: Thu Mar 23, 2017 9:49 pm
by Daggs
Does anyone know the thread dia/pitch for the LEFT hand thread on Lambretta hub-studs. ?
And, does anyone know where I could by a thread tap to do the job?
Re: Hub stud thread
Posted: Thu Mar 23, 2017 10:04 pm
by bristolmod
Andy
why not just replace the stud?
Chris
Re: Hub stud thread
Posted: Fri Mar 24, 2017 8:11 am
by Daggs
I need to tap out four holes to fit SIP long studs.
Re: Hub stud thread
Posted: Fri Mar 24, 2017 10:35 am
by bristolmod
oh I see.
Re: Hub stud thread
Posted: Fri Mar 24, 2017 2:02 pm
by Toddy
M10 x 1 L/H thread e bays a good start
Re: Hub stud thread
Posted: Fri Mar 24, 2017 2:22 pm
by HxPaul
Daggs wrote:I need to tap out four holes to fit SIP long studs.
Dont the SIP long studs just screw in once the original studs have been removed ?
Re: Hub stud thread
Posted: Fri Mar 24, 2017 2:37 pm
by Knowledge
Daggers might be making a brand new hub. I have done this before.
Re: Hub stud thread
Posted: Fri Mar 24, 2017 3:26 pm
by storkfoot
Knowledge wrote:Daggers might be making a brand new hub. I have done this before.
Would that not be a case of re-inventing the wheel ?
Re: Hub stud thread
Posted: Fri Mar 24, 2017 3:27 pm
by Daggs
HxPaul wrote:Daggs wrote:I need to tap out four holes to fit SIP long studs.
They would have done, had the previous occupiers of the holes not been force fitted and e-metaled in.
I have sought out a tap now. As 'Knowledge' says 10mm x 1mm pitch. £20 freaking quid. ( i may consider renting it out)
Re: Hub stud thread
Posted: Fri Mar 24, 2017 5:51 pm
by Knowledge
Daggs wrote:HxPaul wrote:10mm x 1mm pitch. £20 freaking quid. ( i may consider renting it out)
If I can't find my tap, I might be taping you up (gettit?) to borrow it, as I will need to tap mine in a few days time.
Storkfoot, don't forget your coat on the way out.
