Hub stud thread
Daggs
Does anyone know the thread dia/pitch for the LEFT hand thread on Lambretta hub-studs. ?
And, does anyone know where I could by a thread tap to do the job?
bristolmod
Andy
why not just replace the stud?
Chris
Scootering since 1968.
Daggs
I need to tap out four holes to fit SIP long studs.
bristolmod
oh I see.
M10 x 1 L/H thread e bays a good start
HxPaul
Daggs wrote:I need to tap out four holes to fit SIP long studs.
Dont the SIP long studs just screw in once the original studs have been removed ?
Knowledge
Daggers might be making a brand new hub. I have done this before.
Martin
storkfoot
Knowledge wrote:Daggers might be making a brand new hub. I have done this before.
Would that not be a case of re-inventing the wheel ? ;-)
Daggs
They would have done, had the previous occupiers of the holes not been force fitted and e-metaled in.
I have sought out a tap now. As 'Knowledge' says 10mm x 1mm pitch. £20 freaking quid. ( i may consider renting it out) :lol:
Knowledge
Daggs wrote:
HxPaul wrote:10mm x 1mm pitch. £20 freaking quid. ( i may consider renting it out) :lol:
If I can't find my tap, I might be taping you up (gettit?) to borrow it, as I will need to tap mine in a few days time.
Storkfoot, don't forget your coat on the way out. :roll:
Martin
