Page 1 of 2
Ts1 back from MB - bring on the rebuild!
Posted: Thu Mar 16, 2017 8:15 pm
by alanscottj
Got cylinder back from MB - stage 2 road/race tune. Excellent work! Also treat the engine to a new CNC head - lovely bit of kit - shame to hide it under a cowling!
Re: Ts1 back from MB - bring on the rebuild!
Posted: Mon Mar 20, 2017 8:21 pm
by alanscottj
Before I button the side casing up - does anyone use loctite on anything in this side? Clutch nut? Front sprocket bolt? Have torqued up to the recommended figures.
Posted: Mon Mar 20, 2017 8:33 pm
by garry inglis
put some loctite on the clutch nut as recommended by rayspeed as there is no tab washer
Posted: Mon Mar 20, 2017 8:51 pm
by alanscottj
garry inglis wrote:put some loctite on the clutch nut as recommended by rayspeed as there is no tab washer
Makes sense - I'll pop a drop on there and re-torque :D
Posted: Tue Mar 21, 2017 12:29 am
by storkfoot
Chain tensioner are the only threads I put loctite on. Not saying that is right, just what I do.
Posted: Tue Mar 21, 2017 10:22 am
by alanscottj
storkfoot wrote:Chain tensioner are the only threads I put loctite on. Not saying that is right, just what I do.
Yes, did them last time I put engine together. Also used a torque screwdriver to be on the safe side - they are still in ImageImage
Posted: Tue Mar 21, 2017 1:23 pm
by Toddy
What Torque setting do you use for the Clutch , AF's dont give one do they ?
Posted: Tue Mar 21, 2017 1:47 pm
by alanscottj
Toddy wrote:What Torque setting do you use for the Clutch , AF's dont give one do they ?
Got it from Beedspeed's site - 48 to 50 nm so did 50 Image
Posted: Tue Mar 21, 2017 2:09 pm
by garry inglis
Image I have this hope it helps anyone I've converted to Newton metors on the right
Posted: Tue Mar 21, 2017 2:19 pm
by alanscottj
Ah yes, ft lb not nm :o
