Ts1 back from MB - bring on the rebuild!
alanscottj
Got cylinder back from MB - stage 2 road/race tune. Excellent work! Also treat the engine to a new CNC head - lovely bit of kit - shame to hide it under a cowling!
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox πŸ˜ŽπŸ‘
alanscottj
Before I button the side casing up - does anyone use loctite on anything in this side? Clutch nut? Front sprocket bolt? Have torqued up to the recommended figures.
garry inglis
put some loctite on the clutch nut as recommended by rayspeed as there is no tab washer
alanscottj
garry inglis wrote:put some loctite on the clutch nut as recommended by rayspeed as there is no tab washer
Makes sense - I'll pop a drop on there and re-torque :D
storkfoot
Chain tensioner are the only threads I put loctite on. Not saying that is right, just what I do.
alanscottj
storkfoot wrote:Chain tensioner are the only threads I put loctite on. Not saying that is right, just what I do.
Yes, did them last time I put engine together. Also used a torque screwdriver to be on the safe side - they are still in ImageImage
What Torque setting do you use for the Clutch , AF's dont give one do they ?
alanscottj
Toddy wrote:What Torque setting do you use for the Clutch , AF's dont give one do they ?
Got it from Beedspeed's site - 48 to 50 nm so did 50 Image
garry inglis
Image I have this hope it helps anyone I've converted to Newton metors on the right
alanscottj
Ah yes, ft lb not nm :o
