Super/vbb 5 wire stator problems...HELP
nige1972
Howdy, got an old super type 6 volt vespa here im trying to sort the lights out for someone and to be honest its starting to drive me nuts#$# :roll: :roll:
Ive replaced light/cut out/horn switch, rewired the brake light and got it so that when i put 6v dc through the loom it all works ok although the back light is very dim. When i connect it up through the stator yellow light feed i get zilch, no power. Changed stator and exactly same symptoms. If i test voltage out of yellow on stator i get 13 or so volts(both stators exactly the same) Are these 5 wire stators conected through the switch in some perculiar way that the voltage feeds back on itself so everything has to be conected a certain way. I can only think if so that maybe i have the wrong switches for this model..im beginning to think theres some sort of voodoo at work here... :twisted:
