Page 1 of 2
Hydraulic in board.
Posted: Sun Feb 19, 2017 3:51 pm
by psychedelicropcircle
To whom do I send my backplate onto to have this work done?
Re: Hydraulic in board.
Posted: Sun Feb 19, 2017 4:51 pm
by Muppet
try chiselspeed they did mine many years ago
by rosscla
MB will do it.
Posted: Sun Feb 19, 2017 7:05 pm
by hendy
You can buy them already done from beedspeed. Think they're an OK price. 80 quid or so.
Posted: Sun Feb 19, 2017 8:11 pm
Anybody using the already converted back plates? Do they have the thread cut in to house the slave?
Posted: Sun Feb 19, 2017 8:40 pm
by rosscla
Some do, some have one that is bolted down.
Posted: Sun Feb 19, 2017 8:42 pm
by rosscla
You can also get a pop in type that goes behind the circlip, if you want it to be reversible. They're a pain to bleed and I found it quite springy against the circlip.
See here -
viewtopic.php?f=10&t=30622&start=20
Might still be in the shed if you're interested in trying it?
Posted: Sun Feb 19, 2017 9:47 pm
Cheers Rosscla I had a go at one of those scootrs types on a mates bike, ferkin ball ache, so thanks but no thanks.
I was asking incase the beedspeed one was that type.
Posted: Mon Feb 20, 2017 1:53 pm
by corrado
Scootrs used the type that fit behind the circlip whereas the Spaq / Sterling one has a bolt on cylinder.
Posted: Mon Feb 20, 2017 6:39 pm
by roadrunnerian
I got mine from beedspeed had it chromed it has a nissen caliper conversion, used to have a screw in type but who made the slave cylinder put the hydraulic coupling in the wrong place every time I braked the fitting hit the damper
