Hydraulic in board.
psychedelicropcircle
To whom do I send my backplate onto to have this work done?
Muppet
try chiselspeed they did mine many years ago
C’est la vie
MB will do it.
hendy
You can buy them already done from beedspeed. Think they're an OK price. 80 quid or so.
Anybody using the already converted back plates? Do they have the thread cut in to house the slave?
Some do, some have one that is bolted down.
You can also get a pop in type that goes behind the circlip, if you want it to be reversible. They're a pain to bleed and I found it quite springy against the circlip.
See here -
viewtopic.php?f=10&t=30622&start=20
Might still be in the shed if you're interested in trying it?
Cheers Rosscla I had a go at one of those scootrs types on a mates bike, ferkin ball ache, so thanks but no thanks.
I was asking incase the beedspeed one was that type.
Scootrs used the type that fit behind the circlip whereas the Spaq / Sterling one has a bolt on cylinder.
roadrunnerian
I got mine from beedspeed had it chromed it has a nissen caliper conversion, used to have a screw in type but who made the slave cylinder put the hydraulic coupling in the wrong place every time I braked the fitting hit the damper :oops:
