Compression on TS1?
alanscottj
Just bought myself a compression testing kit.
Checked the compression on my TS1 - 225 just to see how the kit works and measured 100psi - kicked engine over three or four times to get to the 100 and that was the max I could register.
Does 100psi sound about right?
Cheers
Scott
mick1
Main scooter: Li Avanti 225
Looks a tad low. Can you check a couple of mates scooters and get a comparison ?
alanscottj
mick1 wrote:Looks a tad low. Can you check a couple of mates scooters and get a comparison ?
Not many TS1's around these parts - maybe some of the chaps on here can share their readings ;)
Scooterdude
When you did the test did you hold the throttle wide open? If not do it again and hold it open!
alanscottj
Scooterdude wrote:When you did the test did you hold the throttle wide open? If not do it again and hold it open!
I didn't no, I will do it again tomorrow :D
garry inglis
Have you done another test alanscottj would like to no the outcome
alanscottj
garry inglis wrote:Have you done another test alanscottj would like to no the outcome
Yup, just done another, throttle open, exactly the same, bang on 100psi - so still none the wiser. Is it too low?
bazza3004
I could be wrong but sure ive seen figures posted of 100 - 120psi
If the gauge was a cheep one off ebay then I wouldn't be too sure of its accuracy tbh. What does the pedal pressure feel like@ should be quite a firm kick needed. What does it run like? good starter? clean plug? 100PSI is low, if it's got some miles on it maybe some new rings are required.
I checked the compression on mine after it seized up last year and I think that was about 100PSI and I could feel the compression had gone when I kicked it over. A strip down revealed stuck rings and damage to the lining.
Scooterdude
I know it's a completely different animal but my 175 conversion was 145psi when I first built it, after I seized it and honed the bore it was down to 125psi. When I seized it again it was down to 75psi which wasn't enough compression to start it.
    Users browsing this forum: Google [Bot] and 19 guests
