BGM FLYWHEEL
Hotdog
In the market for a new flywheel to work with my AF stator plate, and i am interested in the BGM pro flywheel, has or are their any issues with these ?
mick1
Main scooter: Li Avanti 225
Was there some issue with them not working some advance/retard units ?
Hotdog
Is anyone using this set up ! Is it a straight swop from AF light to the BGM ?
ForemanBob
Main scooter: GP RT230
Not using with an AF stator... but... never just a straight swap.
Timing will be different. You have to guess the timing on the bgm, strobe and adjust accordingly.
Also, there is no cover for the flywheel nut or the thread from the flywheel extraction tool, and I it gets covered in crud... pain in the arse to take off the flywheel at a later point.
