Page 1 of 2
How I got a completely stuck mag housing off.
Posted: Sun Feb 12, 2017 11:35 pm
by Davidsquaredson
This is the 63 li150 I got for free. Some idiot left it outside for years. Soaked inside crank area with kroll oil 24 hrs. Crank is shot anyway. I cut the con rod off with a Dremel cut off wheel carefully. Then on the opposite side jammed a wedge in to make the crank evenly solid. The crank is now my drift. Spun it to ensure nothing with catch. Put a small flat bottom 10mm socket on the top of the crank shaft and dropped a screw in it so it stayed in place. This way I would not deform the the teeth and stop it from passing through the bearing. I heated the case hot with map gas and kept heating as I tapped the crank through with a 3lb hammer. Took awhile but the crank pushed the flange out and the dropped out itself. Would of been easier with a second set of hands. And yes I tried the easier things first.
My cylinder studs are frozen in solid as is one case stud. I'm battling some serious corrosion.
Hope this helps someone.
Re: How I got a completely stuck mag housing off.
Posted: Sun Feb 12, 2017 11:37 pm
by Davidsquaredson
Another pic.
Posted: Mon Feb 13, 2017 12:21 am
by YAMLAM
quick clean , new big end and rod, jobs a good un !
Posted: Mon Feb 13, 2017 11:23 pm
by coaster
Good luck with those retaining plate screws
Re: RE: Re: How I got a completely stuck mag housing off.
Posted: Thu Feb 16, 2017 8:02 pm
by Davidsquaredson
coaster wrote:Good luck with those retaining plate screws
As you seem to have skill at predicting the future, can you pick my lottery numbers? I drilled out the peen and used a snap-on tools impact driver. One came off. The other 3 just started to deform. What to do? Heat and keep using the impact driver? Go all around the edge of the screw with a drill bit?
Sent from my SM-G928W8 using Tapatalk
Posted: Thu Feb 16, 2017 8:20 pm
by jonashford
Throw it in the bin
Posted: Thu Feb 16, 2017 8:51 pm
by Scooterdude
If you have access to a welder I'd be inclined to find some old 1/4 sockets and with a grinder clean off any chrome then weld the socket to the head of the screw and undo with an extension bar and socket wrench, doing it this way you have the added advantage of heating the screw up at the same time.
Posted: Thu Feb 16, 2017 10:10 pm
by Davidsquaredson
Scooterdude wrote:If you have access to a welder I'd be inclined to find some old 1/4 sockets and with a grinder clean off any chrome then weld the socket to the head of the screw and undo with an extension bar and socket wrench, doing it this way you have the added advantage of heating the screw up at the same time.
That's a clever idea. I've got a friend who welds. I could take a long 6mm Allen key (or thicker) cut it into 3 sections, and have them welded on top of the screws. Then grab these with a socket.
Posted: Thu Feb 16, 2017 11:05 pm
by hendy
I beat one last year that was about as bad as that. Don't throw it away. I drilled and tapped mine. Built a lovely motor from it.
s**t like this is what it's all about for me.
Posted: Fri Feb 17, 2017 8:29 am
by fluff34567
Heat!
