disc links????
shamrockexpress
Whats the difference in tv series 2 disc links and and gp disc links????????
Daggs
The size of the ball socket. TV2 takes fixed ball rods. GP takes loose ball rods
bristolmod
TV S2 didn't have a disc brake- only a drum. Not sure if the TV2 links are "disc suitable"
Scootering since 1968.
firekdp
Although the TV2 used a drum brake, the links used the same locating attachment as a disc type (stud and nut) so are suitable.
shamrockexpress
Daggs wrote:The size of the ball socket. TV2 takes fixed ball rods. GP takes loose ball rods
so does this mean with GP disc links in a series 2 TV 175 is not really compatible using gp links, is this to do with it lowering the height in the front end making the front wheel look smothered by the mudguard this is what i don't want!!!!!
So can i buy disc links too fit properly into my TV2 175 restoration? Is tv175 series 3 the same or are they like GP
thanx in advance
Daggs
If you intend to both use a disc brake and retain the original fixed ball rods?
Links to suit this are now being made.
http://www.ebay.co.uk/itm/LAMBRETTA-SX- ... SwUuFWwuiy
I'm sure that there's a difference in angle on S2 to S3 links, Shocky is the man to ask.
DigDug
The Winter Model TV2 had a disc brake.... (Just saying)...
Did you have to do that?
Lambretta Sash
+1 on the angle of links, it was mentioned in the webster book and recall the early ones had there advantage ...?
shamrockexpress
Lambretta Sash wrote:+1 on the angle of links, it was mentioned in the webster book and recall the early ones had there advantage ...?
so were do you get these links are they remade??????does anybody no the exact differences???? any body got a set for sale????
