Jetting Dellorto PHBH 28mm
Scootermonkey
Hi. I've looked through the carb set up section on here but can't find anything to match mine.
Standard SIL200 apart from Asso piston, Casatronic ignition, 42mm AF clubman. Anyone know a good starting point with the jetting for the 28mm carb. Will be fitting a Ramair filter. Any ideas welcomed.
How hard can it be!
Lambretta, the finest scooter............IN THE WORLD!
Lambretta Sash
Av264, x13 t2 120 main 50 pilot should be a good ball park
Scootermonkey
Thanks you
How hard can it be!
