Page 1 of 2
Oil seal removal [emoji24]
Posted: Fri Feb 03, 2017 9:04 pm
by randylearner
Evening all.
I'm pulling my hair out,
Trying to remove oil seal and can't budge the thing.
Got impact driver and broken a few pieces now. Had heat on it.
Started drilling pop out of seal
What's next
https://www.flickr.com/photos/151493805 ... ed-public/
Sent from my iPad using Tapatalk
Posted: Fri Feb 03, 2017 9:21 pm
by drunkmunkey6969
You need to remove the for screws and the oil seal plate first......?
Re: Oil seal removal [emoji24]
Posted: Fri Feb 03, 2017 9:22 pm
by randylearner
Hello drunk photo attached, on Flickr
Posted: Fri Feb 03, 2017 9:25 pm
by randylearner
That's what I'm trying to get off. Bloody thing won't budge.
Posted: Fri Feb 03, 2017 9:36 pm
by fairspares
if you cant budge the 4 screws /bolts with a screwdriver or impact, get a long dot punch and tap the corner of the slot anti clockwise carefully or even a thin bar grind to fine point , this will loosen the screws then they will just come out .
Posted: Fri Feb 03, 2017 9:38 pm
by hendy
Posted: Fri Feb 03, 2017 9:41 pm
by randylearner
fairspares wrote:if you cant budge the 4 screws /bolts with a screwdriver or impact, get a long dot punch and tap the corner of the slot anti clockwise carefully or even a thin bar grind to fine point , this will loosen the screws then they will just come out .
Will have a try. Fingers crossed.
Posted: Fri Feb 03, 2017 10:02 pm
by randylearner
Cheers hendy
Posted: Sat Feb 04, 2017 12:02 am
by Chris in Margate
Good bladed screwdriver. If it has a flat near the handle, even better. Grip this with adjustables or mole grips and keep strIking the handle end of the driver firmly whilst trying to turn screwdriver with grips.
Posted: Sat Feb 04, 2017 12:23 am
by bazza3004
Always managed to get them out with a decent impact driver myself . well once i had the impact driver set to the correct rotation :)
