Few final niggles
tippo88
Finally almost finished my LI125 restomod but have a few niggles to sort:
1.Gear change is very stiff and reluctant to go into first. Helps if I roll it forward while changing.
2. Have a Kytronic 2.5 fitted can't seem to get a spark when set to zero ie passthrough but good spark on other curves such as no 7.
3. It's possible to push the headlamp back in its housing slightly is this normal or have I missed a bit?
4. It seem impossible to get the kickstart rubber to stay on the lever. Tried some glue but doesn't seem to help.
Any suggestions much appreciated.
Tippo
Sent from my EVA-L19 using Tapatalk
