fitting a 62 mm stroke crank
sjc
would it be worth fitting one to a standard ts1 set-up,,, :oops:
Boreham
Main scooter: GP225
The larger stroke does give more torque, however if you go down the route also use the longer 110mm rod so you can set the timings easier (also remember you will need to machine the housing to accept the longer stroke)
