rally electronic ignition wiring loom etc question
smoore-gt225
Main scooter: lambretta GT200
hi ive just converted my rally 180 to ducati type electronic ignition (p2 crank with the lip removed, px stator adapted to fit over the bearing housing) that is all up and running fine but now I need to sort the looms switches etc
I can find some light switches but none of them are like the one on the scoot and I think it is a shutter type switch already (if some one can confirm that would be great)
also I found a loom at beedspeed would this be the one I need https://www.beedspeed.com/vespa-wiring- ... 14vk34b354
brake light switch was easy and do I need a 12v horn
cheers in advance
I did a similar thing with mine. I've used this loom on mine.
This brake light switch.
This ignition switch.
The horn is just a regular 12v one.
Loom comes with extra cack you don't need. But it seems well made. Better than any (off the shelf) Lambretta one I've used.
smoore-gt225
Hi that's great but was hoping to keep the original ignition switch, and I wouldn't want that light switch that comes with it as it has a kill switch on it
and my switch only has 4 wires cheers again
firekdp
It looks like a switch from a battery model to me, so should be fine.
