Clutch slip mugello 225
Posted: Sat Dec 24, 2016 8:32 pm
by mr mugello
Clutch is slipping . Standard clutch fitted apart from stronger springs . New springs fitted with new plates last time. Clutch was nice and light in use. Just wondered what is the life of the springs. Should I be replacing them with new ones every time I refit new plates ? Cheers
Re: Clutch slip mugello 225
Posted: Sat Dec 24, 2016 8:42 pm
by bazza3004
What type/grade of oil are you using in your engine
Posted: Sat Dec 24, 2016 9:01 pm
by mr mugello
Clutch has had reasonable working use over a few years with standard 90 oil
Posted: Sun Dec 25, 2016 1:42 am
by bazza3004
If your going to change plates id try something like motul 10/30 2t transoil swapping to this cured the slipiwas getting on my imola
